see wall in 3d but not in floor level
3 ANTWORTEN 3
Nachricht 1 von 4
tpreisler
1685 Aufrufe, 3 Antworten
Hi, i am seeing walls in 3d but not in floor level. I checked my view range, crop region visible but still doesn't show up?
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: tpreisler
Could you post more details?
Have you tried creating a "fresh" view for the level? Have you checked workset visibility as well?
Nachricht 3 von 4
Is it a structural or architectural wall?  What phase does it belong to?  Are the Phase and Phase filter the same between the 3D view and the floor plan view?
Nachricht 4 von 4
chrisplyler
This happens most commonly for me when the bottom and depth values of a view's view range are set to the default of zero, and I've placed structural walls, which default to a depth condition instead of a height condition. In other words, placing such walls without first modifying the depth/height condition results in those walls being placed from the associated level DOWN below the view range.
You can easily check for this in your 3D view by clicking on one of the offending walls and checking its constraint values in the properties pallet, or in your plan view by setting the depth value of the view range down below zero and seeing if the offending walls then show up.
If this IS the case, select all of the offending walls in your 3D view, and change their constraint values so that they will exist with a height above the associated level instead of a depth below the associated level.
Other possibilities may include:
Walls placed with ANY constraint values that make them outside of plan view's view range.
Walls category turned off in plan view.
Walls placed in workset that plan view doesn't show.
Walls placed in phase that plan view doesn't show.
Walls placed in design option that plan view doesn't show.
