See callouts below or above cut plane
1 ANTWORT 1
Nachricht 1 von 2
Marcus.Isacsson
295 Aufrufe, 1 Antwort
Hi fellas!
I wonder if it's possible to see callouts below or above current levels cut plane.
Would be neat of we could see them in a coordination view, having all details on current level visible together.
1 ANTWORT 1
Nachricht 2 von 2
kadmonkee
als Antwort auf: Marcus.Isacsson
it can work as long as the host view has an underlay set and when you go to the call-out view that is also set.
looking down in one view looking up in another view but I don't think it can be done in a callout view in both directions
not Ideal but it does work that way
maybe with view templates it can be more useful
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
