SECTIONS
18 ANTWORTEN 18
GELÖST
Nachricht 1 von 19
georgehobel
793 Aufrufe, 18 Antworten
SECTIONS
im sure this is simple... but I havent found the answer...
Working on a house that is three levels.. Why, when I create a section while viewing my first floor plan, is that section visible or not visible on other levels, assuming I have my VG set to show sections on all levels.
George Hobel
Reflections of Charlotte
Residential Building and Design
18 ANTWORTEN 18
Nachricht 2 von 19
als Antwort auf: georgehobel
Does this help...
...if I drag that top grip down below the upper Level, that Section Marker will not be seen in the upper Level.
...it could also be due to View Scale.
Nachricht 3 von 19
georgehobel
als Antwort auf: barthbradley
yeah that's it... i hadnt thought of that... just something that was bugging me.  thank you
George Hobel
Nachricht 4 von 19
georgehobel
One thing leads to another....
So I can now see my siding in section view.. that's what I was after.  But I dont want to see the siding in plan view.  the siding is attached to the wall as sweeps.  There is a place to hide sweeps in VG, but it doesnt seem to speak to the siding... ??? any ideas???
George Hobel
Nachricht 5 von 19
Did you build the sweeps into the wall type?
Nachricht 6 von 19
georgehobel
yes i did... much to your chagrin
George Hobel
Nachricht 7 von 19
No "chagrining" happening here, buddy.  I don't know what to tell you, other than remove them from the Wall Type and do them the other way.  Sorry.
Nachricht 8 von 19
georgehobel
It is only troublesome because I like to pull dimensions from the outside edge of stud at outside walls... i could just pull from center of stud and not be concerned... makes dimensioning easier...
George Hobel
Nachricht 9 von 19
Turn the Walls into Parts.  That would do it.  You could then hide the Siding.
Nachricht 10 von 19
Switch to Fine to see the core and dimension to face of core.  then switch back to Coarse if you don't want to see all the lines, the dims stay.
Nachricht 11 von 19
georgehobel
als Antwort auf: ToanDN
yeah... I had that thought as well... it works if Im pulling dimensions from the core, and the wall is properly built.  There's just too many lines showing with the view set to fine... Cant pull to outside of stud wall if im set to course or medium...
George Hobel
Nachricht 12 von 19
georgehobel
Into parts???? what do you mean... apply the siding as a separate layer to the wall?  Now that seems like a lot of work.
George Hobel
Nachricht 13 von 19
No, leave them in the Wall Type. Just select the Wall and hit the Parts button.  Try it; you'll see what I mean.
...before you ask; NO, nothing is happening to the original Wall when you do this. Parts is just creating new elements from the original wall that are hosted to the original wall.  If you delete or modify or hide the Wall Parts it does not affect the original Wall.
...also note that Parts Visibility is a View Setting.  Three visibility conditions are available to choose from.
Nachricht 14 von 19
georgehobel
Love this group..... seriously.  You guys are all invited to dinner.
George Hobel
Nachricht 15 von 19
georgehobel
cant find a parts button....
George Hobel
Nachricht 16 von 19
Are you on LT?
Nachricht 17 von 19
georgehobel
yes... till my next renewal
George Hobel
Nachricht 18 von 19
georgehobel
it's been good, but Im growing out of it...
George Hobel
Nachricht 19 von 19
Arrgh! Parts is not available in LT.  Man-o-man, your are going to have so much more fun with full Revit.  So much more you can do with it. It'll pay for itself.  With the increase in productivity, you'll have more time to "sweep" -- the kind your wife like to see you doing.  :zwinkerndes_Gesicht:
