I am making shop drawings on a model that was given to me by the main architect on the job. On my elevation sheets, his sections show up. When I add a section to the elevation, however, it will not show up. The view is created, but it's reference does not show up on the elevation. Super aggravating. Help?
The picture is the section view on the left, and the elevation on the right with highlighting where the section should show.
couple things to check:
Verify the interaction of the Depth Clipping of Elevation and the Section area width . Could be here your problem..
https://chronicle.autodesk.com/main/details/5d75ca0c-6e41-4339-b7a2-566b523d109d
Constantin Stroescu
And last, but not least, check the filters applied to either the view, or if the view uses a view template, within the view template. We use filters to turn off different types of callouts (annotation, working, and presentation), so that could be the problem.
Thanks everyone. The problem is within the actual panel itself. The manufacturer is working on it.
