Sections head visibility paramter
5 ANTWORTEN 5
Nachricht 1 von 6
nichlas.aa.holm
536 Aufrufe, 5 Antworten
Hey.
I have a problem with sections head and callout heads, i want to make a parameter there controls the visibility of a label. But, when i make the parameter in revit families, i can't change it in projekt. Can anybody help me??
I have 2 labels in my section heads, one for detail number and a second for sheet number. But i want to make a visibility parameter on the sheet number label.
If anybody already have done it, you can send me the file, then i maybe can see how.
Regards
Nichlas
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: nichlas.aa.holm
You have to use a type visibility parameter and create different section head/callout types, then create different section types using them.
Nachricht 3 von 6
nichlas.aa.holm
als Antwort auf: ToanDN
Hey.
I can't make it work. i don't have the possibility too change different types.
Nachricht 4 von 6
@nichlas.aa.holmwrote:
Hey.
Make a new section head family -- and assign it a new Section TYPE through Additional Settings=>Section Tags.
Duplicate, Rename and select the new section head family from the drop-down under "Section Head".
Nachricht 5 von 6
s.czykwin
But changing type ot the section change view type and change section heads label in every view where this particularry section head is visible. We need few section head/symbols on different views (created from one section view) but this few section head/symbols created from one view section - has to be look in different ways regarding for example from floor view scale or something. In other words - we have 4 duplicated floorplan view. On one of them i draw section view. This section view (represented by section head and tail)appears on other 3 floorplan views. I need to this section symbol (section head) looks different on each copied floorplan but still represent one view section.
Nachricht 6 von 6
Simon_Weel
Unfortunately, that's not going to work. Changing the Section Type is project-wide. Maybe a good idea to post in the Idea's forum - different Section Types for different View Types?
