Sections and Callouts missing
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
2280 Aufrufe, 3 Antworten
I'm have an issue with section and callout tags showing up in my plan views. I can create the section in the "not working" plan, but it will show up in a lower level plan... so its there, view is created as well.
Currently I have checked; hidden views, visibility graphics for both the individual view and the view template, removed the view template, compared the "working" view properties and the "not working" view properties and they are the same, check the scales and they are the same, looked at worksets and design options also the same in both views.
What am I missing?
Images below are a comparison of plan properties.
Not working planNot working planWorking PlanWorking Plan
3 ANTWORTEN 3
Nachricht 2 von 4
Luiscko
als Antwort auf: Anonymous
Hello i  think you need to see my video where i can show the differents issues that you maybe have for this particular hide elements in a particular view.
https://youtu.be/LU3NMCHfLaY
If i resolve you problem you click in Resolve.
See you.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
Nachricht 3 von 4
Are you, by chance, looking for this:  "Hide at scales coarser than" ?
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Nachricht 4 von 4
als Antwort auf: barthbradley
Thank you for your help i'll check it out for future reference in case this happens again. but it turns out on of my coworkers had turned on a filter that i was unaware of.
