Project sections and call outs not visible in roof plan
Have tried
-changing Visibility graphics
-Scale Corser than settings
- Hidden Elements
- View Range heights
I can see them in every other plan view and elevation except this one
check your phasing? thanks
Unsure which plan i can adjust this on? I tried on my elevations but that did not work
@StephaniePhillips2269 wrote:Unsure which plan i can adjust this on? I tried on my elevations but that did not work
Go to the Section View itself. You may need to check "Crop Region Visible" in the Section View Properties to turn on the Crop Boundary so you can select it .
untick this two and see if helps. thanks
the only way is to share the file here so we can check or if not you can share link and PM me to download the file. thanks
or you can also try this , you can create a view template in the view that you be able to see your project section and call outs then apply to the views you don't see them if you managed to see them change the view template to none and see if helps. thanks
i'm not the OP here. your link is not working and please read.
Since you don't have a view template applied, check if 'sections' and 'callouts' are checked to show under annotation categories in VG for the plan view. If the section does not show up its extents might be below the cut plane (actually you've set VR to unlimited so that's not it) or it's placed in a different phase or discipline ie. It could also be related to view filters.
@StephaniePhillips2269 wrote:This did not make it visible
See if this list of 33 helps you helps you.
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
Without more information, it's a guessing game.
Share the model and end all doubt.
