Sectional drawings from a family
2 ANTWORTEN 2
Nachricht 1 von 3
403 Aufrufe, 2 Antworten
Hi there,
I would like to know how I can make a family drawing of a window and then use it in the future with customized measurements.
After I have made the family and entered a specific size for the window, I want it to make a sectional drawing so I can see the element from the respective angels and also in 3D view.
I would like the fini result to be like this (i know how to make it in inventor):
2 ANTWORTEN 2
Nachricht 2 von 3
Corsten.Au
als Antwort auf: Anonymous
Hi
i would suggest , take any window, edit the family and study the graphics and details.
Visibiliy: plan, view ( coarse, fine etc )
visibily : cut line, projection lines, material etc
as long as you figure out those parameters, you can achieve what you are looking for..
best luck
Corsten
Building Designer
Nachricht 3 von 3
Load the family in the project normally and create Assembly from one instance of the family. Then you an create Assembly views and sheet similar to what you show.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
