Section shows full sheet name
lisa66SHW
Observer Observer
lisa66SHW
Observer
Observer
Hi! I would like to remove the sheet name from the section. I can't seem to find where to remove it from?
Anyone out there who can help me? 🙂
Kind regards,
Lisa
blank...
Section has a type. It uses section tag.
Section tag has a type. It uses Section Head family.
Drill through all three levels to find which section head is used.
Edit that family. There's a label in it. Edit it and remove/set parameters.
Gerben_TVDB
You should delete the view name label in the Section Tail family (Sektionspil1/2).
mari.shimode
Hi @lisa66SHW, did you find the information provided useful? If so, please use Accept Solution so that others may find this in the future. Thank you.
Mari Shimode
