Section showing IFC Elements behind cutting plane
RSE_GSA
RSE_GSA
I've created a section in Revit, and when in the section, I see elements of a linked IFC file that are actually behind the section plane. These elements shouldn't appear in the section as they don't cross the section plane. Why does this happen? I also created a 3D view oriented to my section to compare how the section should look
nahnah19
Try this:
Visibility graphics >> Revit Links Tab >> Set it to by Host
If you have it cut by Linked view now so your CUT PLANE is fixed as per linked model.
RSE_GSA
Unfortunately, it didn't work. Also in my plan views I see some elements above the cutting plane. Do you have another suggestion?
