section of stair going the wrong direction
6 ANTWORTEN 6
Nachricht 1 von 7
drubinoff
291 Aufrufe, 6 Antworten
I have created a stair that has three runs and two landings within.
The first run has curved edges and seems to be going up the wrong direction from the rest of the stair (the portion showing 3 to 1 should be 1 to 3). How do I fix this?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: drubinoff
Edit sketch of that bottom run and redraw the stair path in the correct direction.
Nachricht 3 von 7
drubinoff
als Antwort auf: ToanDN
Thanks @ToanDN , but that does not work. It's insisting on this one direction.
Nachricht 4 von 7
Share the stair model here.
Nachricht 5 von 7
drubinoff
Hi @ToanDN ,
Here's the model. The views to specifically regard are Area Plans (Snipes LOD) GROUND LEVEL. and 3D View 10.
Thanks for looking at this.
Nachricht 6 von 7
See revised model.
- edit sketch
- mirror the sketch lines edit to match existing
Nachricht 7 von 7
drubinoff
Hi @ToanDN ,
Thank you very much for fixing this. I was able to copy your fixed stair and place it in my model (so I can get on with my evening).... I appreciate it!
Independently, I did try mirroring the riser lines as you said, but I was not able to get this bottom run to reverse direction. So, I'm not sure why that worked for you.
Derek
