Hi, I can place and view sections in the ground floor plan, but having issues with not being able to see the section symbols in any other Plans or RCP's (and this is for any section symbol I place). For trouble shooting, so far I have tried:
- Sections are turned on and set to visible in Visual Graphics
- In section, dragged the section box so it encompasses the entire building past the roof and the basement
- Plan, RCP and Section are all in the same phase and under the Architectural discipline (tried coordination as well)
- the sections do not appear in RCP when you click the Reveal Hidden button
- Phase Filter set to Show All in all views
- checked the "hide at scales courser than", it is set to 1/32" and all the views are at 1/8"
- Visible in Option is set to "all"
- when opening the Type Properties of the sections, the "view template applied to new views" is set to none
Any help will be appreciated, so far the only solution has been to place the sections on the first level and guess-and-check where they fall on the upper levels.
Gelöst! Gehe zur Lösung
Gelöst von Jerry.jc.Wu. Gehe zur Lösung
That was it, it was a filter from a view template imported from a linked model. Thank you!
