Section mark family
Section mark family
PrathapSekar
Section mark family
PrathapSekar
Masters!!!
to show wall section I modified the default section mark, when i'm moving the head away from the center it looks weird. Please refer attached images. I can keep it in center, but the length of the section mark is seem bigger and also the bubble located away from the drag point. Attached family for your reference (Revit 2019).sECTION.JPG
Please help me to get this. Thanks in advance.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
hi, you should remake your family from the default family cause you move the rotation base point
PrathapSekar
Thank you very much for your reply @Anonymous
Could you please give more details to get this. Confess myself that i don't know how to control the rotation base point on section head family.
Thanks again.
Hi @PrathapSekar ,
Do you have an image of what you are trying to achieve?
The rotation point is at the middle of the two ref plan
Try with this
