Hello
Now i make a template and i make parameter to sort my Browser Organization with it i need when i create a section to assign to this parameter by default, how can i make this?
Gelöst! Gehe zur Lösung
Gelöst von RobDraw. Gehe zur Lösung
Gelöst von _Vijay. Gehe zur Lösung
i need when i make a new Section by default to put in Fire Fighting parameter in my Browser
once you created the section in correct browser organization. then create the view template from view as in below image. when apply the view template to section, that section automatically will gone with correct browser organization. Even if you create section with view templet it will create from correct browser organization.
That's right i need to make it with out assign View template, by default make this section in Mech and Assign to Sub-Dis. parameter
Use this to automatically apply a view template upon creation of sections. Make more types for different trades if necessary.
