AnzeigenĀ Ā nurĀ  | Stattdessen suchen nachĀ
Meintest du:Ā
Section Box creating new walls
3 ANTWORTEN 3
Nachricht 1 von 4
bdobing1
265 Aufrufe, 3 Antworten
I have linked the grey building and the massing. I have tried to create a section box for a perspective section but when I have done so, the section box creates this. Has anyone seen  this beforeScreenshot 2024-04-27 150111.png
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
M_Meshal
als Antwort auf: bdobing1
Are you able to select this wall?
I believe that used scope box is touching this wall, so a slight slice of the wall will show.
To solve this issue, modify the scope box or you can hide the wall from this view (temporarily or permanently).
Nachricht 3 von 4
bdobing1
als Antwort auf: M_Meshal
The wall looks to be part of the massing. It also only appears when the section box is rotated to be parallel with the building, and not the massing
Nachricht 4 von 4
Simon_Weel
Did you check the Phase and Phase Filter?
In Foren verƶffentlichen
