Hi, how do i get rid of a section box around my default 3d view in revit?
Gelöst! Gehe zur Lösung
Gelöst von rudi.roux. Gehe zur Lösung
Hi @tpreisler,
Go into your Visibility/Graphic Overrides (VV or VG) >> Annotation Categories and scroll down to Section Boxes and switch it off.
I hope this helps! ![]()
Rudi Roux
MSc | Digital Engineering Manager
LinkedIn
Revit Mechanical & Electrical Systems 2018 Certified Professional | Revit MEP & Architecture 2015 Certified Professional
AutoCAD 2015 Certified Professional | Autodesk Building Performance Analysis (BPA) Certificate
If this post resolved your issue, kindly Accept as the Solution below. Kudos are always welcome ⇘
2 ways to get back your hidden section box:
Hope this helps.
If this solves your issue, please click the corresponding "Accept as Solution" button to help others find it easily.
Cheers.
