Section Box - Angled?
hi all
Is it possible to creates non Square/ Rectangular shaped Section Box?
I want to do a Section Cut of this Building which has a Triangular Shape.
Any direction here would be great or tutorial video.
See attached visual where I have aligned 3D View to Section Cut against one side of building but the opposite side (Right) is at angle.
kadmonkee
it is not possible.
it needs a perpendicular alignment
cutting multiple section and aligning them may get a result similar to what you want but is the work )extra effort worth it?
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
You can rotate the entire section box but not individual sides.
