Hi, I have created Section Tag for Section Head and Tail with Reference Label.
1. I cannot see the Reference Label in floorplan.
2. That section line between Section Tags - any option to modify it?
Check that you have defined the tag in the section properties.
You can change the section line type and colour under object styles.
1. Thanks for the objects styles!
2. Ok, correct me if I am wrong. When I want to have any text (reference label/section name) right next to the section head/tail, I have to create Callout head for the Section Tag?
Because I have just created section mark (reference label) in Section Head family.
In plan after this I see only Section Head without that Text.
See above for question 1, you can check project browser if the tag has been loaded into your project. For the second question you can set the section line graphics with object styles (annotation objects) under visibility graphics for your views. You can select a line style specified under manage -> additional settings -> line styles. ps. you can also break the section line or create a split segment when selecting the section.
edit: didn't notice the object styles remark above, so actually both answers were there. ^^ cheers.
Yes, that's correct, but check in the family that it has a reference to the sheet.
