Seam between Neighboring curtain walls
6 ANTWORTEN 6
Nachricht 1 von 7
dgoff96
357 Aufrufe, 6 Antworten
The project I'm working on has a curtain wall facade that is based on a module that is flipped back and forthtypical_module.JPG
As you can see, the ends of the curtain wall don't have a mullion. This is so as I copy to the next unit over, the two combined panels will equal the typical bay. My problem arises when I copy the next unit over. There is a visible seam between the two units
double_modules.JPGI'm looking for a way to eliminate that line between the two curtain walls, so that space reads as a typical bay. Any thoughts would be greatly appreciated.
Thanks!
Tags (1)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: dgoff96
Change one panel to Empty, select the other and edit in place to stretch it to fill the adjacent hole.
Nachricht 3 von 7
Are you saying that the "seam" is the Grid Line between the adjacent panels? Also, I not understanding understanding what you mean by "copy the next unit over". Are you saying that you are copying Curtain Walls (not Panels)?
Nachricht 4 von 7
als Antwort auf: ToanDN
What about just removing the Grid Line? Or am I misreading what 's going on here?
Nachricht 5 von 7
als Antwort auf: barthbradley
I think he was talking about 2 adjacent curtain walls, not panels.
Nachricht 6 von 7
dgoff96
Yes, I would be copying curtain walls next to each other which is causing
the seam
Nachricht 7 von 7
