Script for Renaming Multiple Grids
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
o.hatilov
675 Aufrufe, 6 Antworten
Hi.
I am new to working with dynamo and dont understand how to rename multiple grids.
So I have the list of grids that we have in project, and I want to reanme it by the second list that I have. I need to change in Numeral grids (1s, 2s...) to (1c, 2c...) and Alphabetical (A, B, C...) to (А, Б, В...) and (As, Bs...) to (Ас, Бс...)
In two lists I write it in the same row the Name that I want to change. But it doesnt work. It work only if change the name one by one.
Tags (1)
Beschriftungen (1)
6 ANTWORTEN 6
Nachricht 2 von 7
RDAOU
als Antwort auf: o.hatilov
@o.hatilov
Why don't you simply change/type them straight into the model. that would save you at least 50% of the time needed
  1. for retyping the existing names
  2. and for putting this graph together
Apart from that you could do better with the following nodes
  • Package: proruBIM Grids Renumbering
  • Then instead of retyping the existing names...simply get the value of the name parameter
  • Then comes the renaming part...Changing (1s, 2s, 3s...etc) to (1c, 2c, 3c...etc)
    • You can either use the node String.Replace to swap the s for a c
    • Or alternatively, ignore the existing name and use a couple of OOTB nodes to create a a running number + a suffix string and write that to the Grid name
I believe this should be sufficient to put you on the right track
Nachricht 3 von 7
o.hatilov
als Antwort auf: RDAOU
Hi, thank you so much for your help. It worked and I changed the numbers with S to C, but with Alphabetic should I make lots of Code Blocks, or there is another solution?
Nachricht 4 von 7
RDAOU
@o.hatilov
What do you mean exactly by alphabetic? You want to change the ABC to russian alphabit?
Nachricht 5 von 7
o.hatilov
Hi.
Yeah. I want to change from ABC to Ukrainian alphabet, but specificly the letter the I choose (for example from English A (1-st letter of Alpahbet) to Ukrainian Г (4-th letter of Alphabet) and so on. Thats why I think that if I have lists with letters in right slots it will change the same number of slot from 1. A to 1. Г and so on.
Nachricht 6 von 7
RDAOU
@o.hatilov
K, I think I know what you mean..In the original post you were trying to create List of original name and list of new name then use replace...which doesn't work with that node regardless of the lacing you try to use.
  • An easy and simplified way to do that is to just 1 complete list of all the new names then use  setparametervaluebyname to rename them all to new
  • Another more specific way is to use Dictionaries to change the name only specific grids (ie: replacing only portion of the list) see example below...
There are several other way  to do this  (also including replace) but these are the easiest I think
Nachricht 7 von 7
o.hatilov
It worked) Thank You so so much)
