Scope Box Size
5 ANTWORTEN 5
Nachricht 1 von 6
526996629
496 Aufrufe, 5 Antworten
Scope Box Size
Is there any way to draw a scope box with a specific size? It seems the tools 'move' or 'align' do not work on this cuz you won't be able to pick up a point or line on the scope box.
5 ANTWORTEN 5
Nachricht 2 von 6
rxi.gg
als Antwort auf: 526996629
I think not, and it is also quite annoying not being able to put an exact angle
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 6
No. Not even with API or Dynamo.  However, a scope box is to ensure every view using it having the same crop, not sure why do you need it to be dimensioned.
Nachricht 4 von 6
Lance.Coffey
@526996629I found a fair number of ideas posted for improvements with Scope Boxes, here are a couple that seem related to this topic:
If you would like to see these features implemented, please vote up the ideas.
Lance Coffey
Technical Support Specialist
Nachricht 5 von 6
lucdoucet_msdl
als Antwort auf: ToanDN
@ToanDN
An example of this need would be having two scope boxes with the same relative top and bottom levels but different lengths and widths. Without being able to control the dimensions or use the align tool, all we can do is zoom in and nudge it to approximately the correct place and dimensions.
But close enough is good for me when it comes to view cropping!
-luc
Nachricht 6 von 6
526996629
The purpose is to crop the 3d and 2d views with elements exactly in a zone. I don't want to show any parts out of that zone and I won't separate a wall into small pieces and then do 'hide'.
