Scope box section visibility
martijn_pater
Advisor Advisor
Message 1 of 11
martijn_pater
Just something I've been wondering about lately. Does anyone know why scope box visibility does not affect section annotations which have been associated to it...? Think it could be useful...
Replies (10)
Message 2 of 11
_Vijay
You can turn off while you priting in printing setup.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
Message 3 of 11
martijn_pater
@_VijayLet me clarify. Note: this is expected behavior based on descriptions etc., just wondering why it is the way it is...
Scope box visibility settingsScope box visibility settings
Message 4 of 11
_Vijay
Consider you have big size plan. So you can not show in one sheet, in that case you separate  part wise using scopbox as per project need.
Vijayakumar
Head of BIM
Message 5 of 11
_Vijay
For better clarification..
https://www.youtube.com/watch?v=z_jgIakD-pU
Vijayakumar
Head of BIM
Message 6 of 11
martijn_pater
@_Vijay I know what it is for. I don't think you understand the question, I wasn't asking how scope boxes work, so let me rephrase: Why do scope box visibility settings for a view have no effect on sections associated to it (just grids/levels/refplanes...)
It doesn't make sense to me that it does not control section visibility aswell for sections associated to it.
Message 7 of 11
I thought scope box visibility is meant to show or hide it in certain view. It has nothing to do with cropping applicable elements.
Message 8 of 11
martijn_pater
Yes correct, show/hide it in a certain view. "It" being grids/levels/refplanes, why not sections? The question is not so much about cropping really, let me try and think of a situation to explain what I mean. It's not related to something I'm currently working on fyi, just a question in general.
Message 9 of 11
martijn_pater
Well, not sure if this actually says more then the previous image. But anyway, so I have three scope boxes here where I've associated a section to the third and hidden the scope box in view, imho if I hide that scope box it would be useful if it hides the section with it aswell so you can make cutouts this way for part of a building for example...
Quick exampleQuick example
And on another note: I think it would be useful if scope boxes are set to invisible by default for newly created views...
Message 10 of 11
Martijn.Pater
*bump* as unresolved versions 2020/2021/2022, scope box visibility states for associated sections.
Scope boxes are automatically visible in 3d views and other views where they intersect the view cut plane.
The current state is shown in the Automatic Visibility column. Associated datums are visible in 2d views where their scope box is visible.
Use the override column to change the visibility of a scope box and its associated references in individual views.
Why would it affect associated levels, horizontal plan cut view if you will, and not its associated sections, aka vertical cut views. Maybe I'm missing something. Perhaps it's just me thinking there should be at least one proper method of controlling visibility throughout an entire project, not messing about with filters in view templates or whatever...
Message 11 of 11
Eatoughls
Yes, I need this too. I have the same sections for Architectural and Structural but I do not want both section references displayed and was hoping to just assign a scope box but it didn't work! It makes sense if you could use the scope boxes that way because hiding and unhiding is tedious.
And I would also like to be able to set the default to be invisible or visible each time I make a new scope box.
