Does anybody have an interactive BIM model for a Schindler 2500lb and 3500lb elevator that interacts with the walls in Revit 2017 to make openings and doors, etc, like Revit elevators usually do? Schindler's website only has models from Revit 2011 that don't automatically create doorways, snap to walls, or allow you to change the height/number of landings.
Gelöst! Gehe zur Lösung
Gelöst von Viveka_CD. Gehe zur Lösung
Gelöst von sgoodmansen. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Which "Revit elevators" can automatically cut floors and walls that you are speaking of? I don't remember it comes with any smart things like that out of the box. The usual business is load in a elevator family to get the dimensions required, use a shaft to cut the floors, draw shaft walls, and pop doors in.
Or you can take a look at the tool by Otis see if it can be of any help.
I use digipara's free add in when designing or placing elevators.
https://www.digipara.com/products/digipara-elevatorarchitect/
Hi @Anonymous
Similar thread here
If you want the 'elevator family' to cut walls then make a custom door family as suggested by @rosskirby on the above thread.
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
