Schema Conflicts in Revit 2024 - Conflict when linking a model to a site (updated to 2024.1, still not working)
2 ANTWORTEN 2
Nachricht 1 von 3
ale_jablonski
284 Aufrufe, 2 Antworten
Hi guys, this is the error:
This is my revit version:
When I choose "continue loading..." it still crashes.
And i have a project to deliver next week :grinsendes_Gesicht_mit_Schweißperlen:.
Any ideas guys, please?
Thanks.
2 ANTWORTEN 2
Nachricht 2 von 3
ralphdenhaan
als Antwort auf: ale_jablonski
Can you try to Audit the model before opening?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Nachricht 3 von 3
ale_jablonski
als Antwort auf: ralphdenhaan
Thanks for your reply.
The thing is, after, i found out that sometimes i can't even open 2 different projects at the same time, in that case, opening as Audit helps. But linking a model to a site plan in Audit mode doesn't work either. I wonder if it's caused by enscape materials I used on my model and also on my site plan.
