Scheduling family parameters
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
Xapod
9265 Aufrufe, 6 Antworten
I was making a window schedule and I was wondering why some of the parameters in the family i can schedule and some not. For example I can schedule the total length of the window but not the length of my window frame.
I didn't built the families but what is the reason why some parameters i can schedule and others i can't? Is it because some were made as shared parameters and the others weren't?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Xapod
Those need to be shared parameters.
Nachricht 3 von 7
Sounds like you want to report Rough Opening Width and Frame Width.  Perhaps the family you are using has both and is using the in-built parameters: Rough Width for Cut Opening width and Width for frame width.  If not, I would use those parameters to label your dimensions before creating and adding custom Shared Parameters to the family.  FWIW.
Nachricht 4 von 7
I had this issue on a project, created this dynamo script to copy and paste the values i needed in to a parameter that could be scheduled out (shared/project parameters).
Hope this helps anyone in the future.
https://www.mepnode.com/post/dynamo-copy-parameters-data-to-anonther-parameters-for-scheduling
Nachricht 5 von 7
ankit.kYHRHK
To tackle this issue, I create a new shared parameter and in the family editor add formula to extract the project parameter you want (Shared Para ---- =Project Para). And then load the family to the project. Later in the schedule, I add the newly added shared parameter to pull up all the values which update automatically.
Nachricht 6 von 7
onila1987
als Antwort auf: ankit.kYHRHK
Could you provide snippets on what you did?
Nachricht 7 von 7
octavio.nilaUNGGM
als Antwort auf: onila1987
Nvm, I found they way how to do it. Thank you!!
