Scheduling detail item area per view
1 ANTWORT 1
Nachricht 1 von 2
cbt990
198 Aufrufe, 1 Antwort
I created a shared parameter to manually enter in filled region areas so they can be scheduled.
I want to schedule only filled regions visible in a given view. Can I filter by view?
It would work to create a separate schedule showing the areas in each of the five views, that I can drop under each view.
Revit is amazing
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: cbt990
If you use Revit 2023 you can Filter by sheet.  To filter by view you need to enter the view name to Comments or another parameter and use it to create the filter.
