Has anyone found a way to work with schedules when using a 4K screen?
Even with R2017 the text is still larger than the line spacing when in edit mode which makes them almost impossible to use.
(They're fine once inserted into sheets btw).
Thanks for your help.
Have a look at the display scaling in windows and see if it helps. See THIS thread.
If you are on subscription Autodesk released 2017.1, it also appears to have improvements for high resolution screens.
Louis
Please mention Revit version, especially when uploading Revit files.
Hello Daniel,
My name is Giosuè, and I am a Revit specialist.
Click HERE and please carefully review this article which may help us to resolve the problem. You can also try to use a standard resolution monitor.
If I don't hear back from you within 2 business days, I will archive this case. However, you can still post further questions, comments or concerns in this thread at anytime.
