when i do a duct's schedule, i manage to get in lengh, width, height... without any problem.
But, no way to get in the level parameter (the one which the duct was created).
The "reference level" is a duct parameter inside the "constraints" group.
Why, in the available fields of the duct schedule, i can't find this parameter ?
thanks for your answers.
Franck.
Use "comments" parameter and write anything you want.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
ok but i will not write the level in the comments field for each duct !
i must have about one thousand duct in my project....
@Anonymous wrote:ok but i will not write the level in the comments field for each duct !
But how many Levels do you have? It would be easy to isolate all the ducts in the project and then window select all of the ducts on a particular level and give them the same identifier simultaneously.
