I know there is the colour stripe facility in 2021 but is there any way to visually adjust the heading for each group that we have in a schedule? We have a schedule that has 3 groups of furniture that in the various views displays relative to their assigned groups colour. I've attached a small area to show you what I mean. Those headings are actually rows as far as I can tell, just something in Revits programming I guess.
You can get there by using a Fill Region on a Sheet. To put a Fill Region on a Sheet requires this workaround:
1. Use Detail Lines on Sheet to define the closed boundary for the Fill.
2. Group the Detail Lines
3. Go to Plan View and place instance of Group
4. Edit Group
5. In Group Edit Mode, draw a Fill Region inside the Detail Lines.
6. Finish and close out of Group Edit Mode
7. Return to Sheet to see the Filled Region.
Revit doesn't have any option to color value header. To over come this shortcoming, I use image and stretch the color to fit those row.
