Schedule
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
289 Aufrufe, 3 Antworten
Schedule
Hi community,
Can somebody tell me how this kind of schedule is generated?
3 ANTWORTEN 3
Nachricht 2 von 4
Sahay_R
als Antwort auf: Anonymous
Hi @Anonymous
This looks like a Note Block. Note Blocks talk to a particular tag family and will populate once the tag has been inserted. The text can then be manually inserted.
The other option is to create a custom wall / multicategory tag that talks to a shared parameter that has been created and associated with walls in the project, and that shared parameter also talks to the schedule which populates accordingly.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 4
als Antwort auf: Sahay_R
Thnx for the reply.
However, I can't replicate the desired result with Note Blocks. Maybe I don't know how. It seems that these kind of schedules are 1 columns and above the cell you can insert new rows and then you can write texts and use them in sheets.
Nachricht 4 von 4
I finally understood what you meant.
Thanks!
