Announcements
Schedule wall weight
yes_and_no
yes_and_no
I made a test project, tried to automating weight calc of ext and int walls, attached.
I found the "comment" field can be used as a filter factor for each group.
However once stack walls involved, it seems there are no common parameters between them to filter. I temporarily used a duplicate ext Phase and int. Phase. But it seems too much complication for a calculation convenience.
Anyone ?
jay_colcombe
You could use the “Function” parameter for exterior and interior walls as a Filter.
Scheduling with Stacked Walls has always been a limitation and hence why really only used at concept stage for area and overall volume quantities.
You could create some new wall parameters directly in the schedule to meet you need exactly for filtering?
You can also use a Material Schedule to break walls down further into their layers which may give more filtering options.
Jay Colcombe
Autodesk Certified Instructor
