Schedule Wall Material percentages per view?
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
donnia.tabor-hanson
588 Aufrufe, 13 Antworten
I got a request and I am not sure it can even be done.
I would like some help creating a schedule that has calculations built in to show an overall percentage of a material or wall type for a particular elevation.
Anyone have an idea?
Thanks y'all,
Donnia Tabor
CADMama and Revit Family Counselor
Twitter @DonniaTH
LinkedIn
13 ANTWORTEN 13
Nachricht 2 von 14
For a particular view?  Or do you mean a particular façade?
...if the latter, I'm thinking Assembly to start with.
Nachricht 3 von 14
A schedule for a wall, and in a named view.
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
Nachricht 4 von 14
Assembly Schedule and Filter by Sheet.  That's what I'm thinking.
Nachricht 5 von 14
You get where I'm going; right?
Either Assembly or just customize a Wall MTO by filtering in/out the information you want it to report and then place it on the Sheet next to the Elevation View.
Nachricht 6 von 14
I'm not really clear on the requirements, but perhaps a "Legend Phase" could work here as well.  A "Legend Phase" is a Phase that starts before any construction Phases begins.  The Facade would be copy/pasted to this Phase and all it's elements' Phase Demolished set to the subsequent Phase so none of it's elements impact on the actual Construction Phases.  Views and Schedules would then be created in this Legend Phase.  Schedules are Phase Specific.
Nachricht 7 von 14
als Antwort auf: donnia.tabor-hanson
Select walls on that elevation, enter the elevation view name to the walls' comments, create wall material take off schedule and filter by comments.
Nachricht 8 von 14
FWIW: Just to clarify on what I meant by "customize a Wall MTO by filtering in/out the information you want it to report", this is what I was referring to:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-D...
Nachricht 9 von 14
donnia.tabor-hanson
als Antwort auf: ToanDN
And the winner is..... Thanks @ToanDN for your suggestion. That works well.
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
Nachricht 10 von 14
Good info there also.
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
Nachricht 11 von 14
Another thing I would do is to change wall corner joints to Miter incase you have wraparound conditions.
Nachricht 12 von 14
What! That's exactly what I suggested.
"Customize a Wall MTO by filtering in/out the information you want it to report"
I didn't think an "Expert Elite" would need more than that.  I even hesitated to post the follow-up link about Schedule Filters for fear it would come across as condescending.
Nachricht 13 von 14
And then the designer comes back with, "I don't really need it by view I guess."
I still love my new job!
Thanks y'all,
Donnia Tabor
Twitter @DonniaTH
LinkedIn
Nachricht 14 von 14
That's why God invented beer.  :zwinkerndes_Gesicht:
