Schedule - vertical text - multiline
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
PollyD
349 Aufrufe, 3 Antworten
Does anyone have a solution to do vertical text (as the header only) but wrap the text (or have it show multiline)?  Image below is what I am trying to achieve in a schedule.
3 ANTWORTEN 3
Nachricht 2 von 4
rxi.gg
als Antwort auf: PollyD
Here you are
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revi...
Multiline I think it is not possible in Revit :enttäuschtes_Gesicht:
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 4
PollyD
Maybe one day ... thanks.
Nachricht 4 von 4
rxi.gg
I think that's a good idea for future versions of Revit. Check if anyone has create it, if not you can create your idea to improve Revit here:
https://forums.autodesk.com/t5/revit-ideas/idb-p/302
