Hello All,
I'm not sure on how to go about creating this schedule.....if it's possible
What I would like to do is have a schedule that will quantify a count of a family category in a room. For example, if I have 3 hand sinks in a room, or floor drains, or a structural column....
The other task I would like to do is have the schedule read a door in a wall and that it is located on the north wall of a room?
Thanks in advance.....
Jleibold
Counting sinks in a room- yes, dead easy
Create your "Plumbing Fixtures Schedule"
Add all the fields you need from the "Plumbing fixtures" category
THEN.....
Change the "Select available fields from...." drop down selector to "Rooms" and continue to add the Room fields you need.
Then you can use the usual Sorting / Grouping and Totals features of Scheduling to order / total the Schedule as you need
You can also create a room schedule and embed a plumbing schedule.
If you have different categories then use a Multi-category schedule and pull Room parameters from the Field drop-down.
The other question is a tough one. Maybe type in (NSEW) for each Door's Comments field and use Combined parameter in a schedule.
