I need to see the Length of my Sweep (Placed on my door-family), in a Projekt Schedule.
It seems a bit dificult to add a parameter to the Sweep.
Is it possible?
Picture attac.
Thank you.
Kind regards.
Hi @mrheuseler
Without having a play around maybe the following:
Create Height and width parameter in family.
In the schedule use column with a formulas to times height by two and add width.
This should give you the total length of your sweep.
This is probably not the best way to do this and I'm sure others will come up with better options but its one way of doing it off the top of my head.
Hey,
Thanks for the reply.
I will try to it that way.
Otherwise, I will try to create an Identity Data parameter, and try to schedule that..
