I am using Revit 2017 and I have created an electrical circuit schedule. One of the categories (column) is voltage. I was wondering if it is possible to sum all the voltages in the schedule and show it at the bottom of the list. Everything that I have found online shows that I can add, sub, mult. things that are in the same row but I have not found anything that can sum up everything in one category.
Thanks for any help!
Make sure calculate totals for that field is selected (pic 1) and grand total is checked (pic 2).
Go to the Formatting tab in Schedule Properties.
Select the field with the desired information in it. Select Calculate Totals.
are you talking about a Panel schedule or a custom schedule?
if it is a Panel Schedule you will need to modify the Panel Schedule template
