I tried to schedule stack walls and it seems undoable for me.
Goal: to get the total lengths and areas.
Side Q: how can I assign a parameter to them, like Project ID (which I had for almost anything on the projects), so that might help me to filter out the schedule that has like 5 feet long.
Unfortunately you cannot do much with Stack wall. Your option is to add Prefix "Stack" to the wall type. When you create your stack wall, you choose all the wall type with stack prefix. When you schedule, you can filter any wall that doesn't have the prefix stack. As for assign parameter to stack wall, there is no option for that.
Stacked wall are just a Revit tool to model walls on top of each others. Same as in reality, you would just build or assemble wall by wall until you reach the top. So, you can just schedule component walls of stacked walls and you have all the necessary information.
