I've split a door schedule over multiple sheets and into two columns within each of the sheets. Although it was split into two columns, there is a third title block with no rows below it adjacent to the schedule. I can move it off the sheet, however I have to set the print guidelines different from the rest of the set or it will try to print the full extents including the extra title block. How can I get rid of this third block?
Not following...Are you saying you have 3 fields defined in your schedule, and you only want to display 2 of them. If so, make that third field a Hidden Field.
Or...are you saying that you have 2 header fields with nothing showing under them. Is so, grab the blue dot at the bottom of the adjacent columns and nudge it down a little.
Grab the third column by the arrow symbol (op left of the column) and drag it on to anther column.
Pulling the blue dots down in either section of the schedule with doors didn't get rid of it and the section without door info doesn't have a blue dot.
I moved the extra header over the left most section header and it seems to have disappeared! Thanks!
This didn't work for me. I have two extra headers/titles floating beside my schedule and they won't go away. I've drug the 4-way arrow onto the adjacent schedule. It tells me it can't resize the column and cancels out. Any thoughts?
Don't know if you're still having the problem, but I thought I was having the same issue. You need to zoom in enough to be sure to grab the 4-way arrow handle. If not, you end up grabbing one of the column resize handles. Grabbing the move handle, and dragging the "rogue" header onto a correct header works.
FYI, I thought this wasn't working for me, but it turned out I had like 5 "rogue" schedule headers stacked on top of each other and just had to drag the grip multiple times to get rid of them all.
I dragged the empty columns by the arrow button to the bottom of the adjacent column and it disappeared
