Schedule : sorting issue - families
11 ANTWORTEN 11
Nachricht 1 von 12
RECArchi
845 Aufrufe, 11 Antworten
Situation : I want to create a schedule that counts all instances of the same family in each room.
Thus, I create a schedule and sort with "Family" field, then with "Room:Number" field (it also works with "Room:Comments" if it's typed correctly); and I uncheck "Itemize every instance"
Issue : In a room, if all instances of the same family are from different types, Revit display a blank field, instead of the name of the family. (see attached image)
Edit : Post moved to Revit Ideas :
https://forums.autodesk.com/t5/revit-ideas/schedule-sorting-issue-families/idi-p/10066927
11 ANTWORTEN 11
Nachricht 2 von 12
brian
als Antwort auf: RECArchi
Try sorting by Room:Number first, or just by Room:number.
Nachricht 3 von 12
RECArchi
Hi @brian . Thank you for your reply.
Sorting by "Room:Number" first then by "Family" does not work either. You can try with 2 instances of the same family but with different types placed in the same room : Revit does not display the name of the family in the schedule.
Sorting only by "Room:Number" does not fit my needs, because I want to be able to distinguish different families in the project.
Nachricht 4 von 12
brian
I think you need to sort by "Room:Number" first, and then by "Type", not "Family".
If you use Family, it does not distinguish between the different Types.
Nachricht 5 von 12
RECArchi
... and that's what I want to do!
I don't want to distinguish between types. I want to count all instances of the same families, and write the name of the family in the schedule. But this does not work.
Nachricht 6 von 12
brian
Sorry, I got it now. I just tried it with a window schedule and it works fine.
What family category are you trying to schedule?
Nachricht 7 von 12
RECArchi
I can see it's not working from your attached image. :zwinkerndes_Gesicht:
For example, I can see a blank field on lines corresponding to rooms 107 and 210. I guess in these rooms, you placed windows from the same families but different types. (You can see them by selecting the line, then "Highlight elements in the model".)
In such a situation, I would expect Revit to display the name of the family instead of a blank field.
Nachricht 8 von 12
brian
It is actually working. You can't tell because I'm not itemizing all instances. The blank rows are not what you think, those windows are just not picking up a room. If I itemize all instances I can see that I have more than one type of the same family in some rooms.
Nachricht 9 von 12
brian
als Antwort auf: brian
Here is a small piece of the schedule with "itemize all instances" checked.
If you look at my previous image, you'll notice there are (5) instances of the Unit_Fixed family.
Nachricht 10 von 12
is this what you are trying to do?
Nachricht 11 von 12
Legit issue. As a workaround, you could add a shared parameter to the family and enter the formula value = the family name so that it is not modifiable by edit instance to edit type. Then sort your schedule using that parameter.
Nachricht 12 von 12
RECArchi
@brianand @barthbradley   As I mentioned in my first post, I don't want to itemize all instances, nor sort by Type. Indeed, for large projects, there are often a lot of types and instances : schedule can become really big !
Thank you @ToanDN  for your workaround, it's the only way to solve this issue.
Thank you all for your replies.
Sincerely.
