I have separated a schedule into 4 parts - but I would like to turn off the headers on 3 of the partitions. How do I do that please?
Thank you in advance!
Angela
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
There is no setting for that.
Two possible solutions
1-Remove title/header from the schedule and draw it manually.
2-Split the schedule in two separate schedules. Make sure that you can select your data in your two schedules in complementary ranges
Make the first schedule with headers/title. Make the second schedule without headers and separate it in 3 parts
Louis
Please mention Revit version, especially when uploading Revit files.
@L.Maas. Thank heavens, I thought I was losing my mind for a bit there. Nice picture, BTW, Louis!
