trying to calculate the volum of a column for every level.
In the schedule there is the voce of the fourth floor, that is that join with the column.
I can't to unjoin geometry. If click on column and the fourth floor don't do.
Someone can hep me, please?
Ps.
Is this the reason because is in the schedule?
Is the only answer I I have made myself.
Thank's
Gelöst! Gehe zur Lösung
Gelöst von semko_dm. Gehe zur Lösung
Hi!
The floor is in the parts schedule not because it's joined with the column. Probably that floor just was divided into Parts accidentally...
So, you can delete the floor Part if you don't need it or you can filter it out from the schedule.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
