Schedule Not Showing System Family
4 ANTWORTEN 4
Nachricht 1 von 5
LeeUUSLM
2078 Aufrufe, 4 Antworten
Hi All,
I have created a Schedule to include all elements that contain the wording "Wall" within a custom parameter of "construction_type".
I have loaded the Shared Paramater "construction_type" into a structural beam family and loaded it into my project and it is reporting fine.
However when I load the same Shared Paramater "construction_type" into the project and assign it to the Wall and Roof system families and add the same wording of "Wall" it doesn't show.
Am I missing something ? Is there a reason why it would work with a normal family but not a system family ?
Or why it would work when the parameter is loaded at a family level but not when loaded directly into the project ?
Thanks in advance,
Lee
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: LeeUUSLM
Multi category schedules do not work with system families.
Nachricht 3 von 5
LeeUUSLM
als Antwort auf: ToanDN
Thanks ToanDN,
That will be why then !
Is there any work around with this ?
I was hoping to create a schedule that would give a clear indication to all the modelled elements broken down into Roofing and Walling categories and then subdivided within the schedule to the Product system and system components.
Take a rainscreen wall for example.
The brackets and rails will be modelled as components however the cement particle board would be modelled in as a system family wall.
Nachricht 4 von 5
You can create a multi category schedule for non system families and single category schedules for system families, then place them on the same sheet.
Nachricht 5 von 5
Maybe consider Assemblies and Parts Lists.
