Ahhhh! I have tried everything I can think of but the schedule will not correctly count a particular furniture family type that is in the model. If I select all instances in the plan there are 23 of them (and manually counting this is true). The schedule is only finding 18. These are not overlapping a wall or floor and there are other items in the same rooms that the schedule has no problems finding. Out of desperation I even made sure that all the instance parameters were the same. I am not sure what else to do. This has taken way too much of my time and now I am concerned that there will be other items not counted correctly. I have not used schedules a lot and am not completely familiar with all the issues so maybe there is a simple answer (I hope). What am I missing? TIA
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Thank you! I thought I had checked that already but when I went back they were under existing instead of new. ![]()
