Schedule monitored elements
vitorbortoncello
Advisor Advisor
vitorbortoncello
I would like to know if there is any method to select or filter monitored elements in a model.
I ask because, in cases where two disciplines develop models that share the same element, I believe the element should not appear in the quantity takeoffs of both models — its existence should be maintained in only one file (presumably the original).
Is it possible to identify or remove only the monitored items from a schedule in Revit?
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
RDAOU
@vitorbortoncello
I am 100% sure that monitored elements from links have a built in "Monitor Status" parameter but I am not sure if this parameter is exposed to the user in all Categories that support copy/monitor. Not at a workstation to check and I do not remember if it is exposed (Sorry) but if it not exposed, you can do the following:
  1. Add a project parameter / schedule field Y/N in the model (add to all categories in question)
  2. In use dynamo OOTB node either Element.IsMonitored or Element.GetMonitoredLinkElement to collect all monitored ellements
  3. Set the value of the Y/N schedule field you created in step 1 based on the list in step 2
  4. Finally use the Y/N to filter schedule accordingly
mari.shimode
Hi @vitorbortoncello, did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future.
If you would like to receive more comments or ideas from the community, please let us know.
Mari Shimode
