While I schedule the elements for linked file with Design options, schedule shows only elements which are there in Primary options.
How to see the Schedule of other Design options for linked files?
Gelöst! Gehe zur Lösung
Gelöst von dzanta. Gehe zur Lösung
Yes you can...
see attached files...
Basic steps:
1. Create design options in base revit file
2. Link revit file into another file
3. Create schedule for first design option display
4. Go to Properties of Schedule, Visibility/Graphics Override, Click Edit
5. Click Edit for Display Settings for Revit Link Tab
6. Change to Custom
7. Click Design Options tab within this window
8. Change to desired design option display
9. Click OK several times
10 Repeat for duplicated schedules
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
