I cant able to schedule Base level & Top levels of the generic model family, any ideas regarding this.
Thanks in advance
By default, levels will not come for schedule. However, there's a work around:- you may create a shared parameter of levels and extract them in your schedule.
Hope this helps
Hi Ramneet,
Thanks for your reply, Levels are built-in parameter. We can write levels manually but i want it should be automated
As far as I understand, you have a family designed by someone else and you want to commit its parameters to the schedule list. There is no other way than shared parameters. You have to re-create the parameters yourself as shared parameters. Or you need to get the shared txt from the manufacturer of the family.
Hi ,
I want to schedule these parameters Base level & Top level. unfortunately it does'nt appears in schedule
Can you post the family so I can see what is in it. ?
As is, the OOTB options for scheduling does not or cannot extract and schedule ALL built in parameters. And if the parameter is user defined it must be a shared parameters. Then you can either
An alternative without dynamo would be to model those families in a Category that allows you to schedule Top Level and Bottom Level...example as structural columns
