Schedule kitchen family by apartment number
4 ANTWORTEN 4
Nachricht 1 von 5
andrewFMZYR
310 Aufrufe, 4 Antworten
I’ve created a GIA areas schedule and named all my apartments. I’ve created different kitchen type families using casework and loaded them in. i now need to schedule the kitchens so that I can provide a kitchen count for each type along with the associated apartment number so the contractor knows which kitchen goes with which apartment. I just can’t get the schedule to do it, am I wasting my time or is this possible
4 ANTWORTEN 4
Nachricht 2 von 5
L.Maas
als Antwort auf: andrewFMZYR
If you added rooms to your appartments then you should be able to schedule your kitchen casework.
In your casework schedule you can pull the room information
Louis
Please mention Revit version, especially when uploading Revit files.
Nachricht 3 von 5
andrewFMZYR
als Antwort auf: L.Maas
Thanks for the reply, i need the schedule to reference by apartment number not room.
I have created GIA areas plans and named the apartments and i now want to use that name in a schedule for kitchens.
Nachricht 4 von 5
L.Maas
In that case, no not directly possible. As can be seen from the screenshot. You can pull information from rooms, spaces or project information. There are few ways to go about it.
Add apartment number parameter to your kitchen families (in the family itself or through project parameter).
Add Rooms with an apartment number parameter.
Depending on the amount of apartments you could create a script to pull the information from the area and then transfer the apartment number value to your kitchen families (or rooms)
Louis
Nachricht 5 von 5
blank...
Option 1.
Crate a shared parameter, name it appropriately and select if it's text, number...
Open each casework family and add it to it, as an instance.
Select all casework element in a given apartment and name it.
Sort by apartment in schedule.
Option 2.
Create rooms schedule (It won't be by rooms).
Add another parameter, which will be for apartments.
Embed casework schedule in it.
Manually fill in apartment names in the schedule.
Hide room names field.
Filter by room name so you're left with only the rooms that you need.
See attached files.
