Schedule in Horizontal Format
3 ANTWORTEN 3
Nachricht 1 von 4
Nadeem_Skets
272 Aufrufe, 3 Antworten
can we change format of schedule fromMicrosoftTeams-image (1).png vertical to horizontal row wise
3 ANTWORTEN 3
Nachricht 2 von 4
rxi.gg
als Antwort auf: Nadeem_Skets
It is not possible to exchange rows for columns in Revit schedules
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 4
No, but you could split the schedule. Maybe that would get you to where you want to go.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2022/ENU/Revit-D...
...there's also Rotation on Sheet and Heading Orientation (Vertical and Horizontal).
Nachricht 4 von 4
It maybe easier to export a regular schedule to TXT or CSV, datalink to an Excel file (for future updates), format the Excel file as needed, export to PDF, and link/import the PDF back in Revit.
When Revit model changed, just export the schedule to the same TXT/CSV file, open the Excel file and refresh datalink, re-export to the same PDF, then reload PDF link/import in Revit.
