Schedule Horizontal Alignment Issues
3 ANTWORTEN 3
Nachricht 1 von 4
kmccormickYAYUH
163 Aufrufe, 3 Antworten
I'm seeing an issue where the values of a column that have been set to center align horizontally are not actually lining up. Has anyone ever seen this and/or know the cause/solution? Thanks
3 ANTWORTEN 3
Nachricht 2 von 4
jcurveyS6ZUF
als Antwort auf: kmccormickYAYUH
Does it show this when placed on a sheet as well?
Nachricht 3 von 4
jcurveyS6ZUF
Also, it seems there is a correlation with the 0s that are shifted to the left and the value assigned to the parameter in the column to the right. The 0 is shifted to the left for all rows with a parameter value that starts with M in the column to the right.
Any chance there is a relation?
Nachricht 4 von 4
kmccormickYAYUH
als Antwort auf: jcurveyS6ZUF
You're correct. Upon further review, I've found that all the values that are shifted to the RIGHT are from linked elements. The 'M' value was just recently populated in the elements native to the model in question, ergo the correlation with those shifted to the LEFT
And no, the misalignment isn't present when placed on a sheet, so I guess it's really a non-issue at this point.
Still. Would be curious to know if this is an intentional component of Revit's UI or if it is just another one of those inexplicable "Revit quirks"
