Schedule Formatting
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
1465 Aufrufe, 11 Antworten
Schedule Formatting
Are you able to merge cells in Revit similar to how you can in Exce? I have attached an image of the formatting (from excel) that I need to create in a schedule in Revit. I need three rows to be stacked on top of each other while another row spans the height of the three rows that are stacked. It is difficult to describe in words, please refer to the image. This was done in excel by merging cells but I cannot figure out if it can be done in Revit using a schedule or if there is another way to do this.
11 ANTWORTEN 11
Nachricht 2 von 12
Mirko.Jurcevic
als Antwort auf: Anonymous
Not sure this could be done in Revit. I would say no.
You can, however, merge some cells in rows (select two or more adjacent cells and click Group in the Ribbon), but not in columns. Take a look at the ribbon and see what you can do with tables. That's it.
I recommend sending your data to excel and do this kind of table manipulation with a tool specialized for tables.
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Nachricht 3 von 12
In Revit 2017 you can combine several columns together exactly like what you show.
Nachricht 4 von 12
als Antwort auf: ToanDN
Thank you. We are getting ready to switch to 2017. I have been doing research and found where you can combine parameters (ex: width, height, depth) but I have not seen anything about changing the formatting. Do you have a link that explains how you can do this in 2017?
Nachricht 5 von 12
Mirko.Jurcevic
I have Revit 2017 and I wasn't be able to do that. ToanDN, can you please tell us how to this could be done?
Mirko Jurcevic
Nachricht 6 von 12
als Antwort auf: Mirko.Jurcevic
See attached. For some reason I can embed image today.
Nachricht 7 von 12
I do not see anything attached.
Nachricht 8 von 12
Tags (1)
Nachricht 9 von 12
For some reason my desktop can't attach file, can't embed image, can't view list of post. I had to do it via mobile. What a pain.
Nachricht 10 von 12
Mirko.Jurcevic
Oh, you did not merge rows but combined parameters instead. Great thinking! :leicht_lächelndes_Gesicht:
Mirko Jurcevic
Nachricht 11 von 12
Thank you so much. This solves a big issue for us!
Nachricht 12 von 12
Glad it helps.
Revit schedules can't break different combined parameters to different rows like a Tag label can. But you can accomplish that by adding a bunch of blank spaces in the Suffix fields.
